Thanks, bloodydrake. I am pleased with them so far.
I think I might need to go a little higher on the highlights, but that is always the scary part for me. I prefer a natural look to the hypercontrast highlight to white methods, but there are a few areas that look a little flat, such as the shoulders. Maybe I should deepen the shadows a bit?
I decided to go ahead and take a break from layering on skin colors and switched to base coating Garnuk's, erm...kilt? I am going for a ragged, poorly cured black bear pelt, after all, he is an ogre, so I used walnut brown for the fur and muddy brown for the reverse side.
Since it is fur, I thinned down the walnut brown much more than I usually use for a basecoat so that the paint would easily flow into the spaces between the hairs. Normally I use a water:paint ratio of 1:2 for basecoating. This time I upped the water to 1:1. In addition to getting a more even coverage of the fur, the thinned paint was also easier to clean up with a brush full of water when I got messy and accidentally flicked paint onto an already painted leg.
