How well does airbrushing work on bones?
7 replies to this topic
#1 Frankthedm
Frankthedm
  • 3143 posts
Posted 07 October 2012 - 06:40 AM
Airbrushers, what kind of results have you gotten with Bones?
"Life gives you lemons you make lemonade, Life gives you whales... whale burgers." -Cadaver
#2 "That Guy"
"That Guy"
    Shameless Agitator
  • Artists
  • 354 posts
Posted 07 October 2012 - 08:45 AM
It works great if you don't thin the paint too much or spray them with dullcote or primer first.
Martin is an exceptionally gifted human being, a man of unlimited talent.  His smile brightens the sky, and he could lull a dragon to sleep just by whistling softly.  He's stronger than The Hulk, braver than Captain America, smarter than Iron Man, and Chuck Norris fears him.  A scholar and a gentleman, he is nothing less than the most exemplary ideal of humanity for whom exists no limit of superlatives.  He is Martin, Man of Action! -Buglips
Posted Image Posted Image
#3 Wren
Wren
  • 1634 posts
Posted 07 October 2012 - 09:37 AM
I did a durability test on different prep methods for Bones. The minis were tossed in a box and shaken and heavily handled through two conventions. The one 'primed' with Dullcote fared the worst, it has extensive chipping.
#4 Mclimbin
Mclimbin
  • 718 posts
I'm thinking of getting into airbrushing too, especially for some of those dragons and the big models.
Ceci n'est pas la pipe que vous cherchez.
#5 "That Guy"
"That Guy"
    Shameless Agitator
  • Artists
  • 354 posts
Posted 07 October 2012 - 10:01 AM
It's a load of fun. The airbrush does have a steep learning curve though, but one you figure it out, it's awesome.
#6 Niranth
Niranth
  • 484 posts
Posted 07 October 2012 - 11:05 AM
One thing that helps me is that you can practice with water on the same piece of cardboard over and over. (Just let it dry between times) Then I'll use a mix with water, acrylic ink and acrylic medium on cheap paper occasionally to compare things I've learned. I've only only used it to base coat warjacks and SDE monsters with zenithal lighting effects, but it is a lot of fun!
I picked up a Iwata Neo at Hobby Lobby with a 50% coupon and a compressor with fittings inluding water trap at a local home improvement store for around $100. The compressor is a little loud, but the tank is large enough that it doesn't run often. When finances improve, I may look for a better airbrush now that I'm getting comfortable. (Darn Kickstarter!)
Bones KickStarter Links: http://www.reapermin...kstarter-links/
#7 dispatchdave
dispatchdave
  • 760 posts
Posted 07 October 2012 - 11:36 AM
::sigh::
With 300+ Bones coming, I've got to get my regulator fixed.
Even if you only use the airbrush for your base coat, it'll increase your efficiency/decrease your time per model greatly. If you have an army to paint quickly, there's really no other way to go.
-Dave
Hirst Arts Molds: 40, 41, 42, 43, 44, 45, 50, 54, 56, 57, 58, 59, 61, 80, 85, 201, 202, 230, 235, 240, 245, 250
#8 Pole
Pole
  • 413 posts
Posted 08 October 2012 - 07:58 AM
They used the Purple Worm Bones mini at the Airbrush class at ReaperCon this year. Airbrushing a unprimered Bones mini worked magically! My worm was in a bag I carried around for the rest of the convention, threw in my trunk, and then threw in the minis box when I got home. No chipping and no damage at all.
Mini Painting Goal for 2013: 50 Minis!          2012:  13 Minis Completed...
                               Two Time ReaperCon Survivor
