Brush-on Sealer
7 replies to this topic
#1 Zakmahr
Zakmahr
    Newbie
  • 1 posts
Posted 06 September 2012 - 10:12 AM
I normally use Krylon matte varnish (spray) to seal my minis. However on my latest project, I decided to add a waterfall effect to the base after I mounted the mini to the base. I'm not sure if the spray on sealer will agree with the realistic water I've added.
My question is this: is the Reaper brush-on sealer supposed to be thinned before applying it, or do I use it straight from the bottle? I've thinned down the brush-on primer... but this is a different situation!
#2 Furongian
Furongian
    Instigator
  • 178 posts
Posted 06 September 2012 - 05:52 PM
Yes, you can use Reaper brush-on sealer straight out of the bottle. Once it's dry it is completely invisible.
#3 mikem91
mikem91
    Instigator
  • 196 posts
Posted 06 September 2012 - 06:31 PM
A matte sealer on a water effect probably won't look good. My advise would be to seal everything but the water effects. If you must seal the water effects, use a satin or gloss sealer.
#4 smokingwreckage
smokingwreckage
    Gawdlike!!
  • 7487 posts
Posted 06 September 2012 - 11:23 PM
Like mike said: I'd go for gloss sealer or no sealer at all on the water.
#5 zoroaster100
zoroaster100
  • 446 posts
Posted 08 September 2012 - 07:39 PM
Does anyone know if Liquitex Matte Varnish works well as a brush-on sealer for miniatures?
#6 vutpakdi
vutpakdi
    Knight-Errant
  • Black Lightning
  • 2602 posts
Posted 08 September 2012 - 07:42 PM
Works just fine, though it seems to have a little less matting agent as the Lascaux that I normally use. Still get a decent finish, and if I worked with thinner coats, I'd be able to get more matte with a bit more effort.
I do normally push both through an airbrush.
Ron
ex Black Lightning, Houston Metro area
#7 Wren
Wren
  • 1634 posts
Posted 09 September 2012 - 08:55 AM
Anne has said in the past that Reaper brush-on sealer should be slightly thinned with water for the most matte effect.
#8 vutpakdi
vutpakdi
    Knight-Errant
  • Black Lightning
  • 2602 posts
Posted 09 September 2012 - 09:25 AM
That also applies with the Liquitex and Lascaux.
Ron
