Fautly primer can or is this just the way they are?
#1
Posted 06 September 2012 - 05:28 AM
#2
Posted 06 September 2012 - 05:44 AM
On trick I have learned is don't start spraying on the mini. Spray off to one side and then walk the primer over the mini and then stop when the spray is no longer on the mini. This tends to prevent splatter.
I tend to use Armory primers, so I can't speak to Citadel primers specifically.
#3
Posted 06 September 2012 - 05:48 AM
It sprays smooth, as thin as you like and is way more cost effective than boutique primers like Citadel, Army Painter, etc.
#4
Posted 06 September 2012 - 05:53 AM
Current Bones Count: Total: 109 Painted: 81
#5
Posted 06 September 2012 - 05:58 AM
(Spray primer coldly directs gaze at your stalwart bottle)I have defeated your nefarious nature with my noble primer from a bottle and stalwart brush of courage.
"I am your father..."
#6
Posted 06 September 2012 - 06:22 AM
"No . . . that's not true! That's impossible!"
"Search your ingredients, you know it to be true!"
#7
Posted 06 September 2012 - 07:04 AM
like i tell my employees at work who complain about working. your here to work right. yes they reply. your getting paid right. yes they reply. good now go clean the restrooms
#8
Posted 06 September 2012 - 07:07 AM
#9
Posted 06 September 2012 - 07:11 AM
#10
Posted 06 September 2012 - 07:33 AM
Just test it before each job, The mist should be fine and even. Blocked nozzle or inadequate propellant is what causes splatter. Use a fairly quick, smooth motion starting off the miniature and finishing off the miniature. Holding the button down for too long can cause splatter as well, it beads a bit around the nozzle then *splurt*.
#11
Posted 06 September 2012 - 10:41 AM
If a chicken an a half can lay an egg an a half in a day an a half,
how long will it take a monkey with one wooden leg to kick all the seeds out of a dill pickle?
#12
Posted 06 September 2012 - 06:00 PM
I'd like to second Adrift's motion that you consider switching to Krylon. I use Krylon Dual paint + primer and it excellent quality and has a very smooth finish. Moreover, whereas Citadel primer sells for about $20 CDN for a 278 g can (7.19 cents per gram), Krylon Dual retails for about $8 CDN for a 340 g can (2.35 cents per gram). So Citadel costs more than three times as much as Krylon for a similar quality primer.
#13
Posted 06 September 2012 - 07:47 PM
#14
Posted 06 September 2012 - 11:31 PM
#15
Posted 07 September 2012 - 02:25 AM
Once the primer dries it won't matter.For those using Krylon primers - I thought they were all oil-based products - does this not affect the adhesion of acrylic paints? Is there a special acrylic Krylon primer I should be looking out for? There are several places where I live that sell Krylon but all the primers I have found are oil based.
The Holding upside down routine does help. Also if you are doing a lot of spraying, one of these make things easier on your hands...Well my mission for the weekend will be holding the primer can upside down and see if that cleans it out any and trying a few more stores to see if I can find primer.
Propellant ate the paint into the plastic? I had that happen to an old Epic Titan.However, I've also tossed out minis after spraying them with a larger $8 can of Citadel primer as the results were so bad as to not be worth trying to salvage.
"Life gives you lemons you make lemonade, Life gives you whales... whale burgers." -Cadaver
