65085 Wraith Harvester
6 replies to this topic
#1 Silas Coggeshall
Silas Coggeshall
  • 532 posts
Posted 18 July 2012 - 01:00 PM
My second wraith complete. You probably didn't know, but I have gotten some MSP paints. Mainly the core colors. I also got white and blue citadel paints to see if I'd like them better or not. I did not. On this mini I did the stark contrast with the white, but the citadel white didn't go on very well. :( Anyway I hope you like. btw I know the stark white was a little much for a brown robe, but it kinda just happend. I originally was doing a grey base coat, but when I did the brown wash it was a little to thick and turned out like a glaze. :P Anyway thanks for reading. :)
Posted ImagePosted ImagePosted ImagePosted ImagePosted Image
#2 MonkeySloth
MonkeySloth
  • 2430 posts
Posted 18 July 2012 - 04:40 PM
Your shades aren't dark enough and your brights are too bright for not blending--build up to the white by mixing the base and white together in various stages to create a progression. The shade you're using is a good start but you should have one more level that's a much darker brown or purple (don't go completely black but you can mix some in). That being said you're getting the basics of the placement right.
@monkeysloth
---My Tutorials---
#3 Vicky
Vicky
    Instigator
  • PipPip
  • 146 posts
Posted 18 July 2012 - 04:44 PM
Sorry you had trouble with the paint, but I'm really liking what you did here. Sure, it's a bit rough, but the color contrast realy gives me a sense this creature is moving about at night. The stark highlights put me in mind of glints of moonlight against the darkness of its robes. Very nice capture of mood!
#4 Silas Coggeshall
Silas Coggeshall
  • 532 posts
Posted 18 July 2012 - 06:14 PM
Thanks. :) I will say this mini turned out a LOT different than I expected. Like I said I originally had done the base coat grey, and I planed on blending the white highlights with the base coat more smoothly, but after the washed ended up glazing it I just went with the flow. :P I probably will go back and try out the shading though. Thanks again. :)
#5 Silas Coggeshall
Silas Coggeshall
  • 532 posts
Posted 18 July 2012 - 06:15 PM
Thank you. :) I know usually the stark contrasts don't look to well half of the time, but I really liked how this one turned out. Thanks. :)
#6 MonkeySloth
MonkeySloth
  • 2430 posts
Posted 18 July 2012 - 11:08 PM
Washes will stain paint just like a glaze but washes are much, much, stronger then an adverage glaze so if you water a wash down it will probably have the effect you want.
Also I forgot to mention how nice this photo turned out. Looks like you've got a good system going.
@monkeysloth
---My Tutorials---
#7 cerebro1974
cerebro1974
  • PipPipPipPip
  • 531 posts
Posted 18 July 2012 - 11:23 PM
I agree, with most of the above, darker darks, will really make this one sing!
