Thank you.
Posted 03 July 2012 - 08:34 PM
My Miniatures
www.titanscreation.weebly.com
Deviant Art
Facebook
Silas Coggeshall
Posted 03 July 2012 - 11:27 PM
Posted 04 July 2012 - 09:38 AM
lol Yes it's the Reaper Bones line. :P Very fun to paint. I'm glad that I went with the Bones. I may use a lighter color for the highlights on the fur, but I think for now that he's pretty good. I actually only have one tube of brown paint. :P Soon I'll be taking care of the lake of paint. :)Is this the BONES version or the metal one? I have the metal one and the arms were a PITA to glue on even with pinning.
I would highlight the skin one more time to make it stand out from the fur. They seem to similar. Unless that's what you were going for. :)
My Miniatures
Deviant Art
Facebook
Silas Coggeshall
Posted 04 July 2012 - 10:36 AM
@monkeysloth
---My Tutorials---
Posted 04 July 2012 - 10:41 AM
I can see in improvement with this figure over the previous werewolf, good job.
What I like about this paint job is that for the first time I'm really seeing some defining features via shadow and highlights in one of your miniatures and that just makes it stand above most of your other work.
I also took the liberty, I hope you don't mind, of adjusting a few of your photos for clarity.![]()
I used Paint.net, which is free app for windows and really easy to use, to adjust the brightness and color saturation a bit so people could see the brown more.
My Miniatures
Deviant Art
Facebook
Silas Coggeshall
Posted 05 July 2012 - 08:31 AM
Posted 05 July 2012 - 09:18 AM
If you want to pull out the highlights on the flesh more you can add a little bit of white to the brown you have used for the flesh, just enough to make it a little bit lighter, then paint this in as a highlight. Repeat adding more white each time, but painting over a smaller area each time. This is a quick and dirty way to blend highlights onto a model, expecially if you thin the paint a little as you go.
Posted 05 July 2012 - 08:53 PM
Posted 06 July 2012 - 12:36 PM
Posted 06 July 2012 - 03:46 PM
Thank you. :) I have to agree getting your photos to turn out right can be a real pain. :P lolI really like what you did on this mini, and I agree that it is one of your best. The area where you take your pictures needs a little more light however, either from above or in front. I use a lamp at left front about 4 inches higher than the mini, then another at the right front about even with the mini and another about 24" directly above the mini. I still end up adjusting the contrast a little though. Your background can also affect the color saturation and sometimes wash out colors depending on what your camera seems to like. My camera does not like Greens or Yellows and will over saturate them. Experiment with different back grounds and lighting to try to get a photo where it looks close to what you see in hand under normal light. As for the highlights people have suggested, I would agree, but keep in mind that blending them up to the brightest highlight is key so they do not look like layers of paint but a smooth transition. This is easier said than done and takes practice. I still have trouble doing it in some areas of the miniatures. Larger areas are easiest. Keep up the good work and I look forward to watching you progress as you keep painting.
My Miniatures
Deviant Art
Facebook
Silas Coggeshall
Posted 06 July 2012 - 09:41 PM
My Miniatures
Deviant Art
Facebook
Silas Coggeshall
Posted 06 July 2012 - 09:50 PM
Posted 09 July 2012 - 09:04 PM
Note I took care of the white that you see after I spotted it in the picture. The brown highlight was also a little brighter than I wanted, but it still looks good.
Honestly I thought these highlights look better than the next werewolf.
My Miniatures
Deviant Art
Facebook
Silas Coggeshall
Posted 10 July 2012 - 01:20 AM
Posted 10 July 2012 - 08:10 AM
