Tiny Pterodactyl
10 replies to this topic
#1 Shogan
Shogan
    Instigator
  • 185 posts
Posted 01 July 2012 - 08:49 PM
Hi guys! I was hoping for some advice. I am working on putting together a mini for a character in one of the Hollow Earth books to match this picture:
I found a great mini from that is almost identical:
I am going to add a saber-tooth tiger to stand next to him. If possible I would like to sculpt a tiny pterodactyl to perch on his arm to match the picture:
TinyPterodactyl.jpg -
That being said, I have never sculpted with the exception of a few bases and this is a very small scale. Any suggestions on how to do this? I have brown stuff, green stuff and all your basic tools used with miniatures. I could really use any help or suggestions y'all have to offer.
Thanks!
#2 Cronoan
Cronoan
    Mostly Harmless
  • 44 posts
Posted 01 July 2012 - 09:49 PM
I sculpt mostly in sculpey clay and haven't yet tried green stuff, so take this with a grain of salt. With tiny things with a lot of nimble features like this, you want to sculpt it piece by piece and add to it after it cures. That way you won't fudge up parts you've already done when they're still soft and malleable.
So on this little guy, you're going to want to start with his body and work in basic shapes. His body is sickle shaped, so start with a slender egg form that has pointy ends where his neck and tail will go. Make it thinner than it has to be, cause it's ALWAYS easier to add to a piece after it cures, than to carve away when it's too fat. =)
His head and neck are the same way. As the body cures, you can go ahead and add a tiny cylindrical piece at the neck. You can sculpt the head(another sickle shape) separately and attach it when everything has cured, using more green stuff as a bonding agent or pinning it if you're more comfortable with that.
The wings look trickier. If I was using sculpey, I would take a doubled piece of aluminum foil and cut it to the right shape for each wing, coating the whole piece in the tiniest possible layer of clay. Can you core green stuff with foil? Does that work the same way? If you can, that will help it hold its shape until it cures. I might even wrap the upper edge of the foil wing over a floral wire "rod" with a centimeter of rod sticking out where the wing will connect to the body to form a pin connection.
This is just my process as to how I would try to sculpt him, and you don't have to follow it. The basic ideas are again: Sculpt in parts, building up from basic shapes and letting them cure before making connections, and always make the parts thinner than necessary and build them up slowly to the right thickness.
As for detailing like skin abrasions, his back ridges, and his eyes and mouth, I personally find it easiest to add excess strips of clay to an area and carve out the details. Like for his ridges, I'd have a spinal strip and I'd use a small pointed tool to carve dips out of the spine and leave the ridges in place. Other sculptors like to only add what clay they need, in this case adding and blending each individual bump along the spine. Both methods are valid, you just have to choose the one that works for you.
I hope this helps, and good luck! I look forward to seeing what you can come up with. =) Also, if any of that was confusing or you need a visual, I'll be glad to model what I mean and post pics of whatever you need to see.
#3 joshuaslater
joshuaslater
  • 5627 posts
Posted 02 July 2012 - 08:05 AM
I don't have advice, but I'm a great cheerleader and encourager of many a new sculptor, and will be watching this with great interest. Kings to you on such a cool project. ::):
#4 haldir
haldir
    I Don't Look Like My Avatar
  • 11958 posts
Posted 02 July 2012 - 12:29 PM
Perfect saber I think would be this one if your looking for one:
3253:
Posted Image Posted Image Oh what the hell-- Posted Image
ReaperCon goer since 2005!
"The Road Goes Ever On......
"Lop that mutt's nards off spike! " orcsoul
#5 Ironhammer
Ironhammer
    Instigator
  • 248 posts
Posted 04 July 2012 - 06:40 PM
I would reccomend that you start with one of Reaper's dragon familiars, especially this guy from Familiar Pack II
http://www.reapermin...P02399A_w_1.jpg
This way, the wings are already done. I would use side cutters to cut away most of his body, leaving the area between the wings with a little pointy bit of pewter on the front end to give you something to work off of when you're doing the head.
I would reccomend greenstuff for this approach, since it is ahesive when it is freshly mixed and will stick to the metal.
Like Cronoan said, do it a piece at a time.
"To my mind, all good things come to a point....swords for instance" -GK Chesterton Visit my website! http://houseofthegia....wordpress.com/
#6 Metalchaos
Metalchaos
  • 923 posts
Posted 08 July 2012 - 08:56 PM
Maybe the Strige on stump could also work if you remove its back legs and tail.
Yo Ho Ho And A Bottle Of Rum!
My Miniatures Gallery
My Blog
#7 Shogan
Shogan
    Instigator
  • 185 posts
Posted 14 July 2012 - 01:58 PM
Ok. Ive been working on my tiny pterodactyl who will henceforth be known as Pterry. Ive been using thin wire and brown stuff and so far I just have a basic skeleton. I haven't quite mastered how to keep my fingerprints off it and it is a real pain to try and hold since he's so tiny, but for my first attempt to sculpt something I'm pretty pleased. He's coming out slightly larger than I would like so he may have to go on the base rather than the arm but we will see. I really like Cronoan's idea of using aluminum foil for the actual wing, I think I'm going to toy around with that and see what comes of it. I'm enjoying it but I'm finding it to be a frustrating process as well. I think my boyfriend is considering running away until he's finished. I try to walk away when I get too annoyed but I also like to try to push through and build patience. Anyways, let me know what you all think.
#8 Cronoan
Cronoan
    Mostly Harmless
  • 44 posts
Posted 14 July 2012 - 04:32 PM
I think it's an excellent start, the head looks really good and the proportions seem accurate to me. It's good that you're keeping it thin allowing yourself to flesh it out as you go. Keep going, definitely walk away when you're too frustrated. But also remember that sometimes you need to put on a movie and just bust out some crazy work for an hour and a half to get through whatever's frustrating you.
#9 Hibou
Hibou
    Instigator
  • 137 posts
Posted 04 August 2012 - 01:11 AM
That looks great so far. Keep up the good work.
#10 Shogan
Shogan
    Instigator
  • 185 posts
Posted 04 August 2012 - 11:19 AM
I haven't been able to work on it much lately but I've progressed slightly since the last pictures. Since I'm not going to cast this I am blessed to be able to use superglue but I'm trying to use brown stuff more when I can to get the practice. I found a pair of wings that I liked from the bunny in model 01417. I cut them apart and attached them. My legs unfortunately came out of the brown stuff in the process as I am clumsy and this is very small work so as you can see there is glue attaching the legs. Let me know what you think. Comments are appreciated.
P.S. Sorry about the subpar pics. I picked up a new camera and have no idea how to use it.
#11 Boarstorm
Boarstorm
    Newbie
  • 1 posts
Posted 06 August 2012 - 08:45 PM
Pterry is looking great! You're almost there, just keep plugging away at it.
As with all things, practice makes perfect.
