Incubus 14333
5 replies to this topic
#1 murakumo
murakumo
    Instigator
  • PipPip
  • 227 posts
Posted 13 October 2007 - 01:21 PM
Here's the latest piece I have done.. .took me about six to seven hours to paint him up.. .and he's probably one of the best mini's I have done so far.
Front
Back
#2 SaintRigger
SaintRigger
    Evil Mastermind
  • Black Lightning
  • 4009 posts
Posted 13 October 2007 - 02:23 PM
Heyas - Your brush control is improving, and this is a good thing.
Your paints are still going on way to thick, and obscuring your details. Try thinning them down a little bit - maybe add a drop of water for every 2 drops of paint to start. The more comfortable you get, the thinner you'll want your paints - but when it isn't thinned it tends to gloop up and obscure details.
What are you using to prime your models with? This could also be a factor that would help improve your painting
Your color choices are improving too - you have silver on the sword, pommel of the other sword and shin guards - and then gold on the wrists and thighs which help create a sense of movement when looking at the models. You have a green/purple/red thing going on which is leaning into some color theory - for giggles, try a slightly more limited pallet - for example, try different shades of purple, with maybe green as an accent color.
Here is a quick article that describes color theory - and tons of people ehre would be willing to discuss it further. You can learn which colors work well together and why.
You are really making some improvements over the first models you posted! Keep up the good work.
edit - forgot the link to color theory http://www.colormatt...olortheory.html
Edited by SaintRigger, 13 October 2007 - 02:25 PM.
we want revolution, constant evolution
start your engines blow your fuses
burn the bridges for the future
#3 Sergeant_Crunch
Sergeant_Crunch
    God of Overly Complex Tactics and Tactical Errors
  • 8035 posts
Posted 14 October 2007 - 07:39 AM
Looks like you tried a wash this time as well. Definitely showing improvement. Post more!
I'm not so sure I'd want to get hit by a missile with a "dog brain" AI.
My blog:  http://scsminimadness.blogspot.com/
#4 murakumo
murakumo
    Instigator
  • PipPip
  • 227 posts
Posted 17 October 2007 - 04:55 PM
I wnet back and did alot more detail work on the incubus figure to get him ready for shipping off to Frugy for my exchange. Mostly the major changes are the pants color's, the highlights on the wings and the base color. I redid the freehand "star/pentagram" figure on the base with a darker color so it pops a little more.
I hope fruggy likes it... I sent her a picture of it in her message folder. *grins*
Front
Back
#5 Enchantra
Enchantra
  • 10530 posts
Posted 17 October 2007 - 05:37 PM
I agree.
Keep working on your brush control. It's one of the biggest hurdles any mini painter has to overcome. It takes time and practice. Keep up the good work, you're heading in the right direction.
Here's something to try when thinning your paint. Grab a flat surface such as an old ceramic plate - in four places put a few drops of paint. To one add no water. To another well add one drop, to the third well add two drops of water and the last well three drops of water. Mix each up thoroughly and then gently brush it across the surface of the plate. Watch how the paint flows off the brush and how the thinned paint seems to flow better than the paint that isn't thinned. Figure out which amount of added water or other thinners works best for you by experimenting in such a way and stick with that formula until you feel ready to move onto trying other things.
The Federal Government has sponsored research that has produced a tomato that is perfect in every respect, except that you can't eat it.  We should make every effort to make sure this disease, often referred to as "progress," doesn't spread.  -Andy Rooney
#6 Thes Hunter
Thes Hunter
  • 404 posts
Posted 17 October 2007 - 09:21 PM
Murakumo, I think your color choices are great. They certainly work as base colors.
You said you went in and added more detail, and someone said that it looked like you tried a wash.
Wing feathers are great for washes. Did you try a really really really thin coat of black over the feathers?
As for the paint thickness, I agree with the others, this is likely your greatest hurdle. Thin up the paint (and don't worry about translucency) and you will find that you won't have to struggle nearly as much to get good detail on the figure.
I hope this helps, but your figure shows a lot of promise. Keep up the good work! ::D:
