best way to apply static grass
#1
Posted 15 May 2007 - 03:31 PM
#2
Posted 15 May 2007 - 04:24 PM
#3
Posted 15 May 2007 - 07:26 PM
#4
Posted 15 May 2007 - 07:39 PM
And for cripes sake don't get impatient and do it when the mini might still be at all tacky from drying ink or varnish. The grass will stick like a sonuvagun to your mini.
Not that I've ever done that.
Your momma was a lobefinned fish.
#5
Posted 15 May 2007 - 09:23 PM
#6
Posted 16 May 2007 - 07:55 AM
#7
Posted 16 May 2007 - 09:24 AM
The bottle was made specifically for applying static grass. My guess is you could get one on the internet or at a train/hobby shop.
There are also machines that will create a static charge through the grass so it stands up. That's a little over the top for me.
BTW, if you want the finished affect to be matte instead of glossy, use Matte Medium instead of glue to apply the flocking.
#8
Posted 16 May 2007 - 09:26 AM
TS
#9
Posted 17 May 2007 - 04:47 PM
I put a drop of glue down, line up some pieces of grass, then use pick-ups (something like very long, thin tweezers) to grab a clump and shove it on. With the way I use the pickups the grass is already vertical by the time it hits the glue.
Holding the mini upside down for a couple of minutes while the glue dries can help.
#10
Posted 11 November 2007 - 02:01 AM
I figured afterwards since spray sealers could knock the grass flat? But honestly I have no clue about the lil fake grass stuff..... I don;t want it to rot or mutate into some new odd form of life that I'd then have to slaughter in order to reclaim my mini's o__0 ((once bitten twice shy as they say....))
#11
Posted 11 November 2007 - 02:18 AM
I haven't touched the static grass stuff yet, I'm waiting for PTF to show up for a New England Paint Day and teach all of us poor New England folk some base-fu!
Seldom Used CMON thingy - Updated 6-23-09
#12
Posted 11 November 2007 - 03:17 AM
As for getting it to stand up? I've an easy solution for those of us with small, furry children that go 'Meow'. A balloon! Build a charge on the balloon by giving the cat a serious noogie with it and hold the balloon over the mini. The grass stands up (the excess gets sucked to the balloon depending on how good of a charge you built up) and you get to watch the cat spark for a bit while the glue dries.
I have a semi-feral cat who lives in my garage.... I really don;t think I could get away with that and keep my throat intact.
Although with how dignified she acts it might be worth it....
#13
Posted 11 November 2007 - 03:22 AM
#14
Posted 11 November 2007 - 07:13 AM
Just an odd question.. .seeing as tomorrow will be the first time I ever use static grass.... do you apply it before or after the sealant?
I seal first and then apply the static grass. My theory is that I don't want to accidentally get drops of very large dew (sealant) on my grass. If I'm using flock, I tend to flock first and then seal.
Ron
#15
Posted 11 November 2007 - 08:29 AM
Hey Mura! I actually seal the mini first once it's painted to protect the paint job. Then I base everything. Once the base is completely dry I do a light dusting of Testor's dullcote. Works wonders, the grass has never mutated nor has anything bad happened. The one mishap I have seen though it just looked like the grass had frost on it so it didn't look bad. But it's worked a ok for me to seal everything once the mini is completely done.
Me: No, I said, "I can toot my own horn"
